Brand: Speed Queen
Model Number: AWN432SP113TW04
Main Symptom: water on floor after doing wash
What happens & when: Found water on floor after running a load. When facing machine, the puddle was to the left, from the left edge to about 6 inches toward center. When I googled, it suggested a drain issue if there was standing water in tub, which there wasn’t. Google also suggested a leaking inlet valve, but I have had that issue before and this is not the problem. The third recommendation from Google was a damaged hose, suggesting the “tub to pump hose” or the “tub seal where basket meets transmission”. There aren’t many Speed Queen repair places near me, and they don’t stock parts. I am trying to order the most likely parts that could be causing the problem, so when I get a repair tech here, he can fix it without having to go back and order parts and reschedule the visit.
Any suggestions you can make for possible parts would be greatly appreciated.
Thank you,
Linda Galdun
