Speed Queen Dryer model ADE4BRGS176TW01 Quit mid cycle
Brand: Speed Queen
Model Number: speed queen dryer model ADE4BRGS176TW01
Main Symptom: Quit Mid Drying Cycle - Won’t start again - Was heating when stopped
What happens & when: Before it quit, I had it stop once mid cycle. It started again when I hit the “start” button. This time, it quit mid cycle and will not turn on again. I have left it to cool down for days, still does not work. I have tested the Thermal Fuse, Thermostat, Door Switch, Motor, Start Switch, and I tried to test the Timer - All have continuity (if I did it right - They all beeped). When I go to press the Start button, I can hear the timer start ticking, only while I hold down the button. After I let go, the timer stops. When the dryer stopped mid cycle, the heat was working, because the clothes and the dryer were warm. Don’t know what it is or what is causing the issue. I have checked to make sure my breaker didn’t flip as well. Please help? Thanks
That dryer should have this: Basic Warranty: 3-year limited warranty (parts and labor). How old is it.Can you screen shoot a picture of the wiring diagram?
When testing the two outer wires with a multimeter, do you get a 240 Volt AC reading? Also, when the thermostats were being tested, did you notice if the belt was in good condition and had proper tension? Finally, did there happen to be a wiring diagram taped to the bottom access panel or in the console area? If there was, could a picture of it be provided?
