Special Tool
Is there a special tool required to remove/install the lower spray arm support nut?If so, were can I purchase one?
yeap,you coollllll
According to your model number, you will need to remove the screws from the strainer assembly to remove the bottom spray arm. Here is a link to the parts diagram. Hope this helps.
Pump & motor replacement parts for MAYTAG DWU4910AAX DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
