[QUOTE=Gene;4106]Hi Meterman
Most likely you can use the Maytag spark module, part number AP204776
It is designed for four igniters but you can use it for three, just connect the fourth outlet to the ground.
Good luck.
Gene.[/QUOTE]
Thank you Gene. I believe this will work and I’ve ordered it. In fact, my old unit actually has contacts for four igniters but the fourth post is connected to ground.
thanks again, you’ve probably saved me about $1000.
