Source for Whirlpool dishwasher control panel
A repairman has told me that a new control panel for my Whirlpool dishwasher would cost over $400 in bisque (biscuit) color, while the same part in white or black would cost only $150. I have checked internet sources and found the same disparity, which is incomprehensible to me, as the part represents only about 10% of the dishwasher parts. Can anyone direct me to a much more reasonably priced source for part number 8534838, either new or used?
Replacement parts for WHIRLPOOL DUL300XTLT2 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
[COLOR=Blue]A repairman has told me that a new control panel [/COLOR]
Unless the repairman actually did some checks/tests he is making a guess.
The problem you describe in your other post can be caused by either the control board or the control panel (keypad).
Try the below cleaning procedure first.
Try running diagnostics.
If it does nothing, check the switches on the control panel with a meter.
If the panel checks out OK then odds are that it is a control board problem. Still a bit of a crap shoot but you have improved your odds of replacing the correct part.
[COLOR=Blue]Can anyone direct me to a much more reasonably priced source for part number 8534838, either new or used?[/COLOR]
I do not know of a lower cost alternative other than using a white one.
I would not recommend installing a used panel.
At $400.00 it makes more sense to replace the unit.
Even at $150.00 I would not replace the panel unless the unit is in very good shape.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
