Some like it HOT
:cool:
I have a 5 year old Whirlpool Duet electric dryer that functions in all aspects except one. It doesn’t warm the air to a temperature high enough to dry clothes. What diagnostics approach do you recommend? What sequence of parts should be replaced?
Some like it HOT
TJ
Model Search
Here is a tech sheet Note it is for an LW1
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208541833.pdf
And a service manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/cdce3c10dcb5382285256aa20064beaa/$FILE/Duetdry.pdf
I would try different settings to see if that improves drying.
Often what seems like a dryer problem is an air flow problem so try the below.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
Thanks for the insight. I got around to a dismantle, bought an ohm meter and discovered by heating coil had gone bad. I’ve ordered the part and await delivery.
