Soap/rinse dispenser issue
[SIZE=3][COLOR=#000000][FONT=Calibri]I have a Whirlpool Dishwasher model# DU1055XTPQ3 (serial # F54522859) that I am experiencing a problem with. During a cycle I heard a loud buzzing sound coming from the door. I removed the door and found that it was the soap dispenser/rinse aid motor was the source of the noise. I unplugged the wires from the motor and checked the resistance across the motor and it measured fine. I then started a new wash cycle and checked the voltage coming to the motor. It measured 42 volts constantly without decreasing to 0 until the dry cycle started. Would this be caused by some faulty relay in the control board, or burnt out switch on the control board? If it is a component on the control board does the entire control board need to be replaced?[/FONT][/COLOR][/SIZE]
If the dispenser resistance reading is 280-300 Ohms, replace the control board.
Here is the Tech sheet.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL DU1055XTPQ3 Undercounter Dishwasher | AppliancePartsPros.com
