I have a GE Profile Quiet Power II. The soap dispenser will not close so the unit’s door will not close and lock. What is the possible solution? Do I need to remove the entire front panel on the unit?
Thanks for your help.
You will need to remove the door’s inner panel to see what has happened.
Here is a link that may help
http://www.applianceaid.com/dish.html
Check ot 24 and 23 (at the bottom)
Denman–
Thanks forthe reply; the soap dispenser does not lock in place when rotated. I have removed the cover but see no obvious problem. It’s spring loaded so could that be the problem?
Make sure the arm from the timer is letting it latch
