Dear Sirs,
The soap dispenser has a rectifier on it ---- how can I test it??? I do have a VOM w/ diode tester but I do not know how to ust the diode tester section:confused: . I would rather replace the rectifier ( if non-functional) rather than the whole dispenser unit.
Thanks,
Lew L
Hi Lew,
No one service manual has a such diagnosis instructions nor the schematic.
Bosch does not sell such parts.
My recommendation is to replace the whole dispenser as instructed by the manufacturer.
- The part number for the soap dispenser is [COLOR=#800080]AP2834000[/COLOR]
[SIZE=5][COLOR=red]Thanks Gene and others,[/COLOR][/SIZE]
Replaced dispenser in about 15 minutes ( thank God for battery powered screwdrivers ). The little printed circuit board did have a burntout resistor. I’ll be working hard to find this board and if I can’t – it’s off to Radio Shack for the resistor.
Lew
