the dryer will come on and run for about 20-30 seconds and then shut off.
Hi jerryjanice29
Does it shut off completely or there is just a heating part of the dryer shuts off? Please, post as much information, as possible.
Also to provide the most accurate advise I need the complete model number of your dryer. You can find it on the door frame.
Repaired. thanks for the help. Found bare section of wire on door switch wire.
