Shelly
My dishwasher seem to not be getting hot or drying the dishes. When the cycle is done all the dishes have alot of water and seems like a residue on them, I’m wondering how I would know if this just might be the heating element. I got a small part(maybe fuse) but cant seem to see where to replace it. so thought I see what my next step is. thanks shelly
Here is your tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
[COLOR=Blue]I’m wondering how I would know if this just might be the heating element.[/COLOR]
Unplug or remove power from the unit
Remove the kick plate.
Remove one wire from the heating element.
Measure the element with a meter
Should be approximately 20 ohms.
If OK
Remove one wire from the hi-limit thermostat and measure it.
Should be 0 ohms
[COLOR=Blue]I got a small part(maybe fuse) but cant seem to see where to replace it.[/COLOR]
Not sure about the above, where did you get it from?
There is a thermal fuse in the unit but it kills power to the unit.
