Brand:GE
Model Number:FCM16DLWW
Main Symptom: want to run from pure sine wave inverter
What happens & when: need any relavent data/manuals
Hi All,
During power outages (which happen too often if you are a DTE customer), I use a 1kW inverter to power small loads PLUS my freezer, fridge, and furnace (one at a time!). The inverter uses my electric car’s 12V battery as the source of DC.
My freezer is from 1994. That alone is reason enough to replace it.
When I replace it I’m hoping it’s characteristics will be at least as good as the existing one.
Specifically: The existing one, I think, is running about 60% of the time when at 0 degF. This duty cycle is quite awkward (and a sign of age, I know). The existing freezer also draws a high current, 6A I think, when starting and this means it can’t be on the inverter with either of my other major loads.
I’m attracted to the GE FCM16DLWW which runs on 277 kWh/yr in DOE test. Quite good. But I’d really like to know what the duty cycle would be and current drawn when it starts. I have looked for service or installation manual but failed to find. Maybe I’m inept.
Thanks for any finding ANY technical data on this GE FCM16DLWW.
Questions welcome.
Ron
