SCB1001MSS Lose of Control
Brand:GE
Model Number:SCB1001MSS01
Main Symptom:Flickering, unresponsive display
What happens & when: Nothing
Hi there! I’m happy to help you troubleshoot your GE Advantium SCB1001MSS01.
Since the display is flickering and not responding, we could be dealing with a failing display control board, a loose connection, or a power supply issue.
Here’s where I’d start.
1. Reset the power. Turn off the breaker for about 5 minutes, then restore power. See whether the display returns to normal or continues flickering.
2. Check the control panel connections. With power disconnected, inspect the wiring connectors between the display and main control board. Look for loose connections, corrosion, or signs of overheating.
3. Watch how the display behaves. If the display flickers continuously but the buttons still beep, that points more toward the display electronics. If the buttons don’t respond either, the user interface or its power supply becomes more suspect.
4. Check incoming power. If you’re comfortable using a multimeter, verify that the appliance has a steady 120 volts AC at its incoming power connection. Don’t open the microwave’s internal cabinet to perform this test. High-voltage components can retain a dangerous charge even when unplugged.
Before recommending a replacement part, I’d like to narrow this down.
Can you tell me three things?
  • Does the display flicker constantly, or does it sometimes go completely blank?
  • When you press the buttons, do you hear any beeping?
  • Does the oven light come on when you open the door?
Those answers will help us determine whether the problem is most likely in the display/control assembly or somewhere in its power supply, so we don’t replace parts unnecessarily.
Sorry for the delay. I replied to your email directly and not here. To answer your questions:
The display tends to go blank after some time.
There are beeps from some button buttons.
The interior light works but will also stop.
I’ll try to upload a video I made.
Thank you!
I can’t upload the video.
Thanks for the additional information. That helps narrow things down.
On your GE Café SCB1001MSS01, the combination of the display going blank, some buttons still beeping, and the interior light working intermittently points toward an electrical control problem.
I’m leaning toward the display/control board or its power supply, but I’d like to rule out a loose connection or another power issue before recommending a replacement.
Here’s what I’d check next:
1. Try a power reset. Turn off the breaker for about 5 minutes, then restore power. See whether the display returns and how long it stays on.
2. Check what happens when the display goes blank. Press a button that normally beeps. If it still beeps, that suggests at least part of the control system is receiving power.
3. Watch the interior light. When the display goes blank, open the door. Does the light come on, or is it also completely dead?
4. Inspect the control connections. With power disconnected, check the accessible control-board wiring and connectors for loose connections, corrosion, or signs of overheating. Avoid the microwave’s high-voltage components, which can retain a dangerous charge even when unplugged.
What I suspect
If the display flickers before going blank while some buttons continue responding, the display/control electronics become a stronger suspect.
Thank you again! I am away from home. If this is kept open I’ll try to troubleshoot asap.
