Brand: Samsung Model Number: WV55M9600AW Main Symptom: not responding and random lights/ characters showing up What happens & when: not really works, just random lights turn on off and characters on the screen
This was is a flex wash model, meaning it has 2 separate washers, a large one for your everyday clothes and then a small one on top for small things.
Looking at the schematics, it seems that it has 2 separate interfaces, one for each what are the odds of both going bad at the same time? I was thinking it might be the main PCB or possibly something else. Do you still think it might be the system interface?
Do you mind indicting the part you think needs to be replaced?
Is there a way to test this? Im still having doubts that might be this, when taking a part, it seems that the are 2 user interfaces, the one you referenced
