Brand: Samsung
**Model Number:**WF45KK6500AV/A2
Main Symptom: smells like burned rubber/fire when washing
What happens & when: It’s only happened once because I stopped using it. The utility room/into the house smelled like burned rubber/fire after one cycle went through. No error code showed up. Clothes smell like burned rubber. Small plume of smoke filled the air.
