Brand: Samsung
Model Number: WF42H5000AW/A2, version 11 (Serial 000D5NAJB20896N, manufactured 11/21/2017)
Main Symptom: Drum never turns. Washer fills and drains but hangs before the wash tumble ever starts.
What happens & when: Press Start on any cycle. Drain pump runs and purges, door locks, tub fills (stops and resumes filling three times), then the cycle freezes with the display lit but not changing. Drum never moves. Motor hums but doesn’t turn; once it hangs, it goes silent. No code ever shows on screen, even after pressing Start six times in a row. Drum turns freely by hand with normal light drag, no stiffness or grinding. No leaks.
Error Code (if any): None displayed. Stored codes in service mode (Soil Level + Delay End, then Spin, rotate dial): d1 = --, d2 = 3E2, d3 = dE, d4 = 3E2. The dE is probably from opening the door while it sat stalled.
Parts or tests already tried: Replaced the drain pump (new one drains fine). Ran service-mode code check above. Have not yet pulled the rear panel. Looking to confirm whether 3E2 with a hum and a free-turning drum points to the hall sensor (DC31-00098A), the hall sensor harness, or the inverter board, and what the correct inverter board part number is for this version.
Photos / video link: Can send a photo of the model label and of the motor/inverter once the back is off.
With the motor humming but not turning my suspects would be the stator motor DC31-00111A (which includes a new hall effect sensor) or the possibly the inverter board DC92-01531B, but I’d find the inverter to be unlikely. Since the motor is humming it is getting power of some kind, which leans me towards the motor. Check the stator for any damage as well as the rotor DC31-00112A.
You can also test the inverter and hall effect sensor using this screenshot below for reference.
Thanks Rory. Pulled the rear panel and ran the tests. Here’s exactly what I did and what I got.
Stator windings. Washer unplugged, 3-pin motor plug (red/white/blue) disconnected from the inverter. Measured each pair at the plug: red-white 11.8 ohms, white-blue 11.8 ohms, red-blue 11.8 ohms. All three match, no OL. Rotor and stator look clean, no visible damage.
Hall sensor resistance (pins 1-3 and 1-4 from your screenshot). Could not get a valid reading. My meter’s highest ohms range is 2 megohms and it reads OL on both pairs, which it would do on anything over 2 megohms, so that test is inconclusive with my meter.
Hall sensor voltage, sensor connected. Washer plugged in and powered on, no cycle running. Back-probed the 4-wire hall plug on the inverter with needles, meter on DC volts, black lead on the blue wire:
- red wire: 0.15 V
- pink wire: 1.17 V
- orange wire: 3.8 V
No 5 V on any wire.
- Hall sensor voltage, sensor disconnected. Unplugged the washer, pulled the 4-wire hall plug off the inverter, plugged back in and powered on, no cycle. Measured directly on the bare socket pins, black lead on the pin that was blue:
- red pin: 0.00 V
- pink pin: 1.34 V
- orange pin: 3.6 V
Still no 5 V with nothing connected to the board. The green LED on the inverter is lit while powered.
So the windings check out, and the inverter isn’t putting out 5 V to the hall sensor even with the sensor removed. That reads to me like the inverter rather than the stator. Does that match what you’d expect?
One more thing: the label on my inverter board says DC92-01378C. Your reply listed DC92-01531B. Which one is correct for WF42H5000AW/A2 version 11, or does one supersede the other?
I have photos of the board label, the plug layout, and the meter readings if you want them.
With those readings, and if there’s no damage to the rotor magnets or the stator windings, I would lean towards an issue with that inverter. The hall effect sensor may stop the machine after it starts spinning but shouldn’t keep the motor from spinning at all. That hum sounds like the motor is getting some kind of voltage and trying to spin, but probably isn’t getting enough voltage or getting it in the right way, so inverter issue.
DC92-01378C has been discontinued by the manufacturer, DC92-01531B is the replacement part #.
Thanks Rory, that lines up with what the meter was telling me. Stator windings are balanced at 11.8 ohms and the rotor magnets look good, so the inverter is the odd one out.
I ordered the DC92-01531B from you guys today. Once it’s in, I’ll run calibration and post back with the result so the thread has a confirmed fix for anyone else chasing a 3E2 on a WF42H5000AW. Can you please give me the calibration steps so they are in the tread.
Appreciate the help on this one.
