Samsung washer wf42h5000aw a2 began cycling on and off a couple of weeks ago during either the rinse or spin cycle. In the beginning, could get it to complete by switching to rinse/spin cycle. Now, when you turn it on, it usually immediately starts cycling on/off. However, if it has sat for awhile, you can occasionally get it to run rinse/spin. Google search suggested it might be the inverter control board, so I replaced it. Had replaced this 2 years ago as well. Did not help. What next? BTW, there is no error code. EDIT: I have since run the diagnostic and got three codes. SE, DE, and OE. Cant se how these help. Thanks in advance.
Brand: Samsung
Model Number: wf42h5000aw a2
Main Symptom: intermittent power off
Error Code (if any): none
