Samsung washer won't start or stop and door locked
Brand:Samsung
Model Number:WF457ARGSGR/A2
Main Symptom:Doesn’t start or stop
What happens & when:na change options and cycles but pushing start does nothing. Pushing stop/off, shuts of the menu and chimes but then goes to a screen with just SAMSUNG on it and does not shut off. Also door was locked
Error Code (if any): none
Parts or tests already tried: Manually drained. Manually opened door. Hard reset by unplugging for 15+ minutes multiple times.
Seems like maybe main control board but my question is: is part DC92-01032A the right board for my washer and is that likely the issue? I see there is also a controller assembly part DC92-01040A.
Thank you. I resubmitted because I saw a pop-up indicated not to use “general”.
