Samsung washer WA50R5200AW/US51 Will not ADVANCE TO SPIN
Brand:Samsung
Model Number: WA 50R5200AW/US 51
Main Symptom: won’t advance to spin restarts wash cycle
What happens & when:I start a load and the wash cycle usually the quick cycle, warm water and high spin it washes just fine then it does the wiggling dance to set up the machine for spin after the rinse cycle and it does nothing. It just sits there then it restarts to the quick wash cycle like the time will be 10 minutes. Left on spin and then it jumps back to 28 for the wash cycle. I did a ChatGPT and it pointed me to the water inlet valve and pointed me to purchase one on Amazon and gave me how to PDF and a YouTube video we received it and put it on and started a cycle and it acted like it was going to spend then it threw a code Ot
Look that up and it was determined that maybe the hoses were switched but my husband swears they were not switched. It’s impossible to switch them because it says hot and cold red and blue so to the laundromat we go and I’m here putting this question for anyone and up to an including the pros to give me an answer. I’m considering that the replacement inlet valve from Amazon is a dud. I’m just assuming it is because it was from a third-party and it’s not an original equipment by Samsung.
What does it take to get a pro to answer the question?
Parts or tests already tried:inlet water valve threw code Ot
The OT is not a Samsung fault code, It indicates a completion of the self-diagnosis.
If the issue is failing to complete the final spin or stopping the cycle.
Look for the issue/symptom such as an unbalanced load, a drain issue (not draining, clogged pump or hose) worn suspension rods or even an unleavel machine or weak floor.
Reset: press the power button to turn the machine off, or unplug the machine for approximately two minutes…then turn it back on.The washer failing to spin, is usually caused by an unbalanced load, a system calibration glitch, or worn suspension rods. According to the official troubleshooting steps provided by Samsung Support, an overloaded drum or a blocked drain path will automatically halt the spin process.
