Samsung RT18M6213SR stops cooling, works again after 10-15 min unplug, lasts 3-7 days
Brand: Samsung
Model Number: RT18M6213SR
Main Symptom: stops cooling after 3-7 days, unplugging resets it, repeats
5 year old Fridge did not seem as cold and had a constant loud compressor whine which was unusual. Unplugged and found a ton of dust on the condenser coils. Cleaned them, verified condenser fan was working. Plugged in, and all was good and was quiet.
Bought fridge and freezer thermometers, fridge reached 1-2.5C, freezer -22C
Noticed fluctuations every 12-24 hours up to 5-7C fridge, -10C freezer, but realized it was the defrost cycle, and would recover within an hour or so.
Two weeks later, it stopped cooling again, with fridge 10-15C, freezer dropping slower.
Unplug for 10-15 minutes, and it works again for a week or so. This seems to be getting shorter and shorter working for 3-5 days at a time.
LED on PCB is solid red when the compressor is on, no flashing
Error Code (if any): ice maker when run self test with fridge on. But this unit doesn’t have an icemaker
Parts or tests already tried: MAIN PCB CN72 #5 ↔CN73 #1 resistance should be 260 ohm +/- 10% but is 404 ohms. Was expecting 0Ω : Short / ∞Ω : Open(Bimetal / Thermal Fuse / Heater Defect)
Removed fridge panel and the coils were not cold, fan was running, no ice or water present.
Suspect either the control board or the defrost sensors. Unclear why resistance test which checks numerous defrost components is above spec with resistance.
