Samsung RFG298AABP/XAA compressor keeps stopping, inverter board light out
Brand: Samsung
Model Number: RFG298AABP/XAA
Main Symptom: compressor keeps stopping
What happens & when: inverter board light out, compressor stopped, between 6-12 hours
Parts or tests already tried: Inverter board x2, start/run capacitor, main system board
Samsung RFG298 refrigerator. Last month the fridge completely stopped, after diagnosing things it came down to most likely being the inverter board as the LED was blinking 5 times. Ordered a replacement and popped it in - was back up and running.
Things worked great for 3 weeks and then completely stopped again.
Previously, the inverter board would still light up and flash the 5 LED code, but now there was no life to it at all. Thought maybe it was burning boards so I ordered another. In the process of waiting I plugged things back in again and after 7 minutes it was back and running again. Then a week later, same exact thing.
Yesterday, replaced the start/run capacitor and the motherboard. Still goes out. Cannot think of anything else to try. The inverter board led goes off when this happens, but an unplug puts things back to working every single time - until it happens again. Almost seems like it turns off during a defrost cycle and never goes back on, since it is every 6-12 hours. Unsure why it lasted so long after the first replacement though.
Have to keep remote temperature sensors inside and the fridge on a remote switch so I can keep an eye on things and power off/on when temps start to climb.
Been problem free for 16 years until this. Really trying to keep it going until Black Friday.
Ideas?
The fact that the inverter LED goes completely dark when the failure happens is the most useful clue. I would not replace another inverter yet. Since unplugging/replugging restores operation every time, we need to determine whether the inverter is losing its input power/control signal or shutting itself down because of the compressor.
On this Samsung, I’d start here:
  1. Wait until it fails—do not unplug it. With the refrigerator still powered and the compressor stopped, check the inverter board. If its LED is completely off, carefully check for 120 VAC feeding the inverter. This is a live-voltage test, so only do it if you’re comfortable working around line voltage.
  2. If 120 VAC is missing when the LED is out: the inverter isn’t the problem. Something upstream is removing power. Since you’ve already replaced the main PCB, inspect the wiring/connectors between the main PCB and inverter very closely. Look for a loose terminal, overheated connector, poor pin tension, or damaged wire. This would also explain why cycling power temporarily brings everything back.
  3. If approximately 120 VAC is present at the inverter but the LED is completely dead: now check the inverter’s low-voltage/control input from the main board. If the proper control signal is present too, yet the inverter has no LED/output, then the inverter is shutting down internally or being forced into protection by the compressor/load.
The earlier 5-blink inverter code is important. On these Samsung inverter systems, that generally points toward a compressor/inverter drive problem rather than a defrost-system problem. Since you’ve now had the same basic failure with multiple inverter boards, I’d become suspicious of the compressor itself, particularly if its windings or mechanical load change as it gets hot.
I would also check the compressor terminals with power disconnected. Measure resistance between each pair of the three compressor pins. The readings should be relatively low and reasonably balanced. Then check each compressor terminal to the compressor shell/ground. You should get OL/no continuity to ground. Any measurable path from a terminal to the shell condemns the compressor.
I don’t think your defrost theory is impossible, but it’s not where I’d start. A normal defrost cycle can shut the compressor down, but it shouldn’t require unplugging the refrigerator to get the compressor system operating again. The 6–12-hour timing could simply be making it look defrost-related.
The best next test is to catch it failed and measure the inverter’s incoming AC before resetting anything. That one measurement splits this diagnosis in half:
LED out + no 120 VAC → upstream/main-board/wiring problem.
LED out + 120 VAC present → inverter/control-signal/compressor side problem.
If you have a multimeter, I can walk you through exactly where to put the probes on the RFG298AABP/XAA inverter and what readings to expect, including the compressor winding test.
Thank you for the suggestions. I actually went to go test the AC input voltage earlier today, but it seems like it is now playing games with me and it started itself back up before I could get the fridge moved back out.
Back when this first happened I did try and test the compressor terminals, but I couldn’t get stables readings - it was like each time things were jumping around. I did get a few ones that seemed good, but I also have seen where either they should all be equal or two of them should add up to the reading on the third. What I was getting was all being in the same range. That is when I did the inverter replacement, since it the compressor tested bad it would be trash.
I was using alligator clips, so perhaps they were screwing with the readings? I will have to try again now that things have progressed with diagnosis.
Little update. I received my temperature alert and pulled the fridge. Checked for voltage and it has 120v on the OLP/IN section. OLP only, the IN gets around 2v. Same when it is on or off though.
It kicked back on by itself after 20-30 minutes, so it may truly be shutting off completely during a defrost? Unsure why the inside temp goes up so quickly though.
Thanks for the update! That’s actually some helpful information, especially the fact that the refrigerator started running again on its own after 20–30 minutes.
I’m starting to think we may be dealing with an intermittent power or control issue rather than another bad inverter board.
A normal defrost cycle is worth considering, since the compressor and fans shut off during defrost. However, a couple of things don’t quite fit:
  • A 20–30-minute shutdown could be consistent with defrost.
  • The refrigerator temperature shouldn’t climb dramatically during a normal defrost cycle, especially with the doors closed.
  • The inverter LED going completely dark is something we need to investigate further.
Here’s what I’d check next
The most important thing is determining whether the inverter is losing its incoming power or simply being told to stop running.
On this Samsung, the inverter uses both a power supply and a control signal from the main board. These are two different things.
One important question: When you measured 120V at OLP/IN, were you measuring between those two terminals, or from each terminal to neutral?
That distinction matters because the readings mean different things depending on where your meter probes were placed.
The next two tests
1. Check the inverter’s actual power supply. With your meter set to AC volts, measure across L and N at inverter connector CN02. You should have approximately 120 VAC, including when the compressor is stopped.
2. Check the compressor command signal. With the meter set to DC volts, check the compressor control signal at main-board connector CN75. The service information specifies approximately 2–2.8 VDC when the compressor is commanded to run.
Manualzz
+1
If the inverter has 120 VAC but loses its command signal during the shutdown, we need to investigate why the main control is stopping the compressor. If both remain present while the inverter is dark, that points us toward the inverter circuit, connections, or compressor protection.
Safety: These are live electrical checks. Only perform them if you’re comfortable working around energized 120V circuits. Unplug the refrigerator before moving connectors.
Since you’ve already replaced the inverter twice and the main board, I wouldn’t buy another part yet.
I’d especially like to know whether the 120 VAC between L and N stays present when the inverter LED goes out. That one reading should help us narrow this down considerably.
120V is on between L and N on CN02 when the inverter board goes dark.
I get no voltage using DC on CN75, but when testing with AC I get in the above range. Of course it kicked back on in the middle of testing. I will try and catch it quicker next time since I know exactly where CN75 is located and I will check if it keeps that voltage when off.
I am used to freezers and a once a day defrost, so this fridge and its constant stops are throwing me.
By any chance is there a way to trigger a defrost cycle on this?
Thanks for sticking with the testing! You’re getting some really useful information now.
The fact that you’re maintaining 120 VAC between L and N at CN02 while the inverter LED is dark tells us the inverter isn’t losing its main AC power supply. That’s a big clue.
And yes, your Samsung RFG298AABP/XAA has a forced defrost mode. We can use it to see whether the shutdown you’re experiencing matches normal defrost operation.
How to activate forced defrost
According to Samsung’s service information for the RFG298AA series:
ManualsLib
  1. Press and hold Energy Saver and Fridge together for approximately 8–12 seconds, until the refrigerator beeps and the display goes blank.
  2. Wait about 5 seconds.
  3. Press the Freezer button four times, allowing approximately 5 seconds between presses.
  4. The fourth press activates forced defrost for both the refrigerator and freezer compartments.
The first three Freezer button presses command high-, medium-, and low-speed compressor operation.
To exit testing, disconnect power briefly and reconnect it. Make sure the refrigerator resumes normal cooling afterward.
What I’d like you to observe
During forced defrost, check whether:
  • The compressor stops running.
  • The inverter LED goes dark.
  • The 120 VAC supply at CN02 remains present.
If forced defrost produces the same behavior you’ve been seeing, that would support the possibility that some of these shutdowns are normal.
One important correction on CN75
Samsung’s service information specifies approximately 2–2.8 VDC between CN75 pin 4 and pin 3 for the compressor command signal. It is a pulsed control signal, so an AC reading on a standard multimeter isn’t necessarily a reliable indication of what the board is commanding.
EasyManua.ls
+1
I’d recheck that signal using DC volts, measuring between the specified pins, both while running and during the next unexpected shutdown.
Because you’ve already replaced two inverter boards and the main control, I’d avoid replacing anything else until we establish whether the compressor is being intentionally shut down.
One other thing worth knowing: This refrigerator uses a variable-speed compressor and a dual-evaporator cooling system. It can stop and restart more frequently than the older freezers you’re accustomed to. Samsung’s service information also describes a compressor restart delay of approximately seven minutes.
Manualzz
+1
Just be careful around the energized boards during testing.
Here’s my biggest question: When your temperature alert goes off, how warm does the refrigerator actually get? For example, does it climb from 37°F to 45°F, or are you seeing something more extreme?
That temperature change, along with what happens during forced defrost, should help us determine whether this is normal operation or a genuine cooling interruption.
