Samsung RF18A9101SR Defrost drain port constriction and thermal deformation
**Brand:**Samsung
Model Number: RF18A9101SR
Main Symptom: Recurring ice under crisper bins
What happens & when: It’s been a while
Error Code (if any): None
The internal defrost drain port most likely has undergone thermal deformation. The opening presumably has constricted down to approximately 3mm, featuring charred/melted plastic edges. This constriction creates a bottleneck that prevents meltwater from entering the drain line, causing it to back up and freeze in the trough.
Steps Taken & Findings
1. External Inspection (Rear)
  • Duckbill Valves: Removed and inspected both rear drain valves. Both were found to be dry and clear, confirming the blockage is internal (between the trough and the back wall).
2. Internal Disassembly (Evaporator Section)
  • Evaporator Cover: Removed after a manual thaw.
  • Evaporator Coils: Inspected; no heavy “snow” or frost on the coils themselves, suggesting the defrost cycle is triggering.
  • Drain Trough: Found the center drain hole area heavily narrowed. The plastic/rubber “throat” appears melted and scorched.
3. Clearing Attempts
  • Thermal Flush: Used warm water and a turkey baster; water pooled in the trough and would not drain despite the area being thawed.
  • Mechanical Probing: A flexible probe enters the first 1/2 inches of the port but cannot pass through the 3mm constriction into the 90-degree elbow.
Current Status
The fridge has been reassembled and is running to maintain food safety.
This is what google/AI recommends. I’m a handy person comfortable with tools, but I’m cautious about making permanent modifications to the cabinet/insulation without verifying first.
  1. Mechanical Clearing (The “Bore”): You need to physically open that hole. Since it’s already damaged/melted, you can use a screwdriver or a needle-nose pliers to gently clear away that charred debris. You aren’t “poking a hole” so much as “re-opening” the one that melted shut.
  2. The “Sleeve” Fix: If you clear the gunk and find the hole is now too large or jagged, you can buy a small piece of food-grade silicone tubing (about 1/2 inch diameter). Insert it into that hole to act as a “stent,” ensuring water goes into the drain line rather than leaking into the foam insulation of the fridge walls.
  3. Reposition the Heater: Look at the black heater loop. If it is touching that melted area, gently bend it away (just half an inch). It should provide radiant heat, but it should never physically touch the plastic or rubber drain components.
Is the fridge safe?
Yes, but if that hole remains “punctured” or jagged, water will eventually seep into the insulation of the fridge floor. This can cause a musty smell over time.
Your immediate goal: Use a pair of tweezers or a small flathead to scrape out that dark, burnt-looking blockage. If you can get a zip-tie to pass through that spot and come out the back of the fridge, you’ve won. If you can’t, the internal drain tube itself might have melted shut deeper inside the wall, which would require a more “creative” bypass or a professional repair.
Try this: While the area is warm, try to push a solid object (like the back end of a drill bit or a thick pen) through that dark center to “reshape” the hole back into a circle.
With that being down inside the drain where the obstruction is, the only way to do this would be to somehow try to heat it up and then try to work something in there to open it up.
Thank you for your suggestion! One concerning thing is it is not clear if the visible hole is in the middle of the drain pipe or not and secondly how far the hole goes before it turns down. Per some sources, On most Samsung RF18 models, the vertical drop is usually between 1.5 and 2.5 inches before it hits that 90-degree elbow. Would it be a rasonable assumption that the bottom part of the drain pipes has same/almost same inner diameter as the uppper part and the port/expected hole diameter? Also, I’m trying to visualize the 3D path. Is the 3mm constriction likely in the removable grommet or in the fixed drain line inside the foam? I want to make sure I don’t accidentally puncture the elbow while trying to clear the throat.
