Brand: Samsung Bottom-Mount Refrigerator
Model Number: RF18A5101SG/AA
Main Symptom: Refrigerator Compartment temperature is below freezing
What happens & when: It varies between 40 degrees F (set temperature) to 15 degrees F at times, causing refrigerated items to freeze.
Error Code (if any): None
Parts or tests already tried: 12 hour defrost
Photos / video link: N/A
I was originally thinking of replacing the temperature sensor OEM21564426, but I figured I’d check here for more guidance.
Thank you in advance, John
