Samsung Refrigerator RF4287HARS/XAA too warm even with freezer set to "Power Freeze"
Brand:Samsung
Model Number:RF4287HARS/XAA
Main Symptom: Too warm freezer barely freezes water
What happens & when: Stopped making ice, noticed freezer and refrigerator are cool, but not at set point.
Error Code (if any): None
Parts or tests already tried: Compressor appeared to be cycling on and off normally. Cleaned exterior coil, wasn’t too bad. Compressor is not loud or running too hot, compressor fan seemed to be blowing air. Compressor control board LED had no error codes. Turns on and off with the compressor. Defrost drain valve seemed clean and wasn’t holding water. Turned on “Power Freeze” mode which will run compressor continuously. Freezer got a little colder, but barely freezes ice and everything else is soft. Checked refrigerator and freezer setpoints they were normal and set freezer to lowest setting (-8F). Pulled off freezer drawer door and pressed in door switch, freezer fan kicked on and was blowing out of 6 of the 7 ports, it wasn’t blowing hard, but I could feel air movement. Pulled off coil cover, no ice, drain seemed clear, both fans spun freely. There is a little brown discoloration in the defrost catchment pan under the coil. I haven’t inspected anything on refrigerator coil side as it is harder to get all the shelves out etc to access.
Photos / video link: Freezer photos - Google Drive
Judging by the pics u sent and the freezer and fridge only getting cool not cold. I would suspect a sealed system issue. My suggestion at this point would be to have a technician come and examine it
