Brand:Samsung Model Number:rt21m6213sr/aa Main Symptom: What happens & when: compressor clicks but won’t kick on
Error Code (3 blinking lights on inverter boardif any):3 blinking lights on inverter board
Parts or tests already tried: replaced main board and inverter board, homes out compressor
I ohmed the compressor out and it is fine. Is there something else between the boards and the compressor that could be preventing the compressor from kicking on? A relay or a sensor, or anything that would prevent the compressor from coming on?
Nope, a motor can ohm out good, but if it is locked up, it will not run. Some models have an overload located in the plastic cover that covers the compressor pins. If your model has that, you can check it for continuity; if not, we are back to the compressor.
The three blinks indicate the inverter could not identify where the compressor motor position. Since the inverter and the main control have been replaced, this would indicate a failure within the compressor itself.
