Samsung refrigerator has significant issues with its ice maker, does this model utilize a solenoid valve in the ice maker?
Brand: Samsung
Model Number: RF28R7201SR/AA
Main Symptom: Ice maker stops working
What happens & when: Ice make stops working all the time, now making an intermittent buzzing sound
The ice maker in Samsung refrigerators are horrible. It’s a known issue, but the company refuses to fix the problem with their crappy design. The issue is that the ice maker “freezes over” and just stops making ice. You can fix it by defrosting it, which requires taking everything out of the fridge and freezer while it thaws out, which is more than an inconvenience. It will sometimes fix itself, and we have ice for a week or two, but then it freezes over again and we’re without ice for months. Lately, though, it has been emitting a loud hum from the ice maker area, and after some research it appears that could potentially be caused by a faulty solenoid. Looking on the list of available parts for this fridge, though, the solenoid isn’t one of those parts, although when I google the solenoid part number for this model, one shows up. I could buy a whole new ice maker component, though, for the roughly the same price as the solenoid Google shows. But first I need to understand if this model even uses a solenoid valve (I think it does), and if the new ice maker unit would include a new solenoid.
If the water valve is what you are needing then it would be water filter case assembly that would be needed.
https://www.appliancepartspros.com/samsung-a-s-assy-da82-02870a-ap7021798.html
