Brand:Samsung
Model Number:RSG257AARS/XAA rev 01
Main Symptom:will not reset after loss of power
What happens & when:after power loss displays88 88. Will not reset.
Parts or tests already tried: Ordered new control board. Does not work. New board I also checked, and DA41-00522A is the correct control board for your model RSG257AARS/XAA Rev. 01.
The replacement board has a different pushbutton spring design, Open at top. Original had a wire cap to make contact with center pin when pushed. The design difference does not work. Is there an updated version or if there’s another issue
