Samsung, NE63A6511SS, oven - external gets VERY hot, suspect cooling fan
Brand: Samsung
Model Number: NE63A6511SS
Main Symptom: When running the oven the cooktop and front of stove become extremely hot to the touch.
What happens & when: This is a brand new stove out of the box that apparently had a rough transit as the front feet were bent and had to be straghtened then the first issue when I plugged it in was an error code C-d1. The lock was slightly out of place. That is all fixed and no error codes are being thrown, but the current issue is now when I run the oven the cooktop and front door became VERY hot to the touch. Its making a clicking noise every 25 seconds and I don’t feel warm air coming out the front door vent like I think I should. I think the cooling fan isn’t kicking on and I’m wondering if there is some loose wiring/connection or what it defective, but I can’t find where the cooling fan is at on this model to check. Most info I can find talks about the convection fan, not the cooling fan. I also keep getting directed to the Range Vent Main Assembly (Part #DG94-03933A) but this does not look like a cooling fan and I’m not seeing where this is located on my oven.
Error Code (if any): None
Parts or tests already tried: The clicking noise every 25 seconds seems like a good clue and the fact that I don’t feel warm air coming out the front vent of the oven door. I just can’t seem to find where the COOLING fan is on this model.
Since the unit is new, it would be recommended to have service out since it is under warranty. I am not seeing a cooling fan on this unit.
Unfortunately, the unit was in storage during a remodel and so the warranty no longer applies. Additionally I contacted Samsung and there is no service available in my area. It seems it is on me to fix!
Can someone at least help me understand if Range Vent Main Assembly (Part #DG94-03933A) is what controls the cooling of this unit and if so where it is located?
Samsung NE63A6511SS Range Service Manual.pdf (2.7 MB)
See if this is of any help.
