Samsung ne63a6511sg oven
Brand: Samsung
Model Number: ne63a6511sg
Main Symptom: oven element stays on when off
Error Code (if any): 0
Parts or tests already tried: can hear relay click when oven is turning on and off. Not sure what else could be the problem.
If the elements are staying on then this would indicate a stuck relay which would be the control board that would need to be replaced.
https://www.appliancepartspros.com/samsung-assy-pcb-eeprom-dg94-04041f-ap7032730.html
