Samsung NE59J7850WG/AA unable to control heat setting on large 3-ring burner and the "Hot Surface" light stays on continuously
Brand: Samsung
Model Number: NE59J7850WG/AA
Main Symptom: Uncontrollable heat setting and “Hot Surface” light stays on
What happens & when: When using the large 3 ring burner on low, it gets too hot, uncontrollable. When the range is cool, the “Hot Surface” light stays on.
Error Code (if any): None
Parts or tests already tried: None
It sounds like there are two issues going on. The temperature issue would be a failure in the infinite switch not regulating properly. However, the hot surface indicator light would be a failure with the element.
Infinite switch- DG44-01007B Range Triple Burner Switch | Genuine Samsung OEM In Stock
Triple element- DG47-00065A Range Triple Surface Heating Element | Genuine Samsung OEM In Stock
