Brand: Samsung
Model Number: WA48J7700AW/A2
I need to know how to install the Washer Door Lid Washing Assembly. Mine broke, I’ve bought a new one, but there is no place to search for how to install it.
For your Samsung washer, model WA48J7700AW/A2, the lid assembly can be replaced without taking the washer tub apart. Most of the work involves removing the old lid from its hinges and installing the new one.
Before starting, unplug the washer and have someone help support the lid while you remove the mounting hardware. The glass lid assembly can be heavy and awkward to handle.
How to replace the lid assembly
You’ll need a Phillips screwdriver and about 15–30 minutes.
- Locate the four mounting screws. Open the washer lid and look along the left and right sides near the rear hinges. There should be two screws on each side.
- Remove the old lid. Have someone hold the lid steady while you remove all four screws. Carefully lift the lid away.
- Check the hinges. If the new lid doesn’t include the hinge brackets, transfer the original brackets to the new lid, provided they aren’t damaged.
- Position the new lid. Line up the mounting holes with the hinge brackets. Start all four screws by hand before tightening them.
- Check the movement. Slowly open and close the lid several times. Make sure it sits evenly, moves smoothly, and closes completely.
- Test the washer. Restore power and start a short cycle to confirm the lid locks properly.
Samsung’s service information also confirms that removing the lid involves four mounting screws.
Electrical Connector
+1
One thing I’d like to verify
You listed AP5989999. I found the complete lid assembly for this model listed as DC97-18845Q, so I want to make sure we’re talking about the same part.
Parts Dr
+1
Does your replacement include the entire glass lid and outer frame, or is it just the plastic portion of the lid?
That will help me explain the exact installation without having you take apart anything unnecessary.
It is just the plastic portion of the lid.
Thanks for clarifying! On your Samsung washer, model WA48J7700AW/A2, if you’re replacing just the plastic portion of the lid rather than the entire lid assembly, the job should be a little simpler.
The main thing is to determine how the plastic piece attaches to the lid frame. You may not need to remove the hinges or the entire lid.
Here’s how I’d approach it:
- Unplug the washer for safety.
- Open the lid and inspect the underside for screws holding the plastic portion in place.
- If screws are present, remove them while supporting the lid.
- Check for plastic locking tabs around the edges. Release them gently with a plastic trim tool to avoid breaking the surrounding pieces.
- Transfer any handles, bumpers, or other hardware from the old plastic piece to the replacement, if necessary.
Don’t force the plastic apart. Some Samsung lid components are secured together in ways that aren’t intended for separate disassembly.
I also found a repair report for this lid describing how the plastic bezel snaps into place around the hinge spring clips. The installer recommends leaving the rear edge unsnapped until the clips are aligned, then snapping it together and reinstalling the four screws.
Parts Dr
One question: Is the plastic piece you’re replacing the outer frame surrounding the glass, or the smaller plastic washing lid underneath the main lid?
That distinction will help me give you the correct installation steps without having you take apart more than necessary.
