Samsung Ice Maker water won't shut off
Brand:Samsung
Model Number:rs25j50
Main Symptom:Water leak
What happens & when: When water
Error Code (if any): none
Parts or tests already tried: none
Either the icemaker has stopped in a fill position or the inlet valve is ,stuck open. Either situation requires the parts to be replaced. Disconnect the wire harness to the inlet valve. If water continues to come in, replace the valve, it is stuck open. If not, replace the icemaker.
Thanks for the response. Where is the valve located? I don’t see one.
