Brand:
Model Number:WF42H5000AW/A2-11
Main Symptom: does not spin / will not proceed past starting
What happens & when: When I select “Spin” or any standard wash cycle, the door locks and the machine starts, but it never progresses past the 3-minute mark.
I’ve already tried recalibrating the machine using the two-button method, but that didn’t change anything. The washer is a direct-drive model (no belt).
If I run a spin-only cycle, it will drain/eject water, but it won’t actually spin. I’ve also unplugged the machine to reset it, with no improvement.
Any ideas on what might be causing this?
Error Code (if any): none
Parts or tests already tried: recalibrated, unplugged
Photos / video link:n/a
