Samsung electric range ne58f9710ws oven terminal 505 connector on control board has melted
Brand:
Model Number:
Main Symptom:
Error Code (if any):none
This issue will likely need the wiring and connector repaired or replace and if burnt/damaged the control will need to be replaced as well.
https://www.appliancepartspros.com/repair-help/
