Brand: Samsung
Model Number: DW80R9950US
Main Symptom: repac ment door inner assembly
I recently purchased and installed inner door assembly AP7191163 (DD97-00607E) for my Samsung dishwasher, model DW80R9950US/AA.
The replacement door fits correctly, but the detergent/rinse aid dispenser is a different design. The original dispenser (ILTEK) has a sliding door, while the replacement (BITRON DD59-01003A) has a hinged door. The two existing wiring harness connectors do not fit the new dispenser terminals.
I’ve been unable to locate a wiring diagram showing how to adapt the existing harness to the new dispenser.
My questions are:
1. Is DD97-00607E the correct replacement inner door assembly for my model?
2. Is there a compatible wiring harness or adapter for the new dispenser?
3. If not, should I be using inner door assembly DD97-00607B instead?
The new door is already installed and everything else appears to work correctly. I’d prefer to avoid replacing the entire assembly again if a wiring adapter is available.
Any technical guidance would be appreciated. I can provide photos of both dispensers and the original wiring connectors.
Thank you!
