Brand: Samsung
Model Number: DV50K7500EV/A3 01
Main Symptom: Takes too long to dry
What happens & when: We have to run the dry cycle several times before clothes are dry.
Brand: Samsung
Hi mgabrielon,
Try removing the vent from the back of the dryer and run it with the vent disconnected. If it still takes a couple of cycles to dry, unplug the dryer and inspect the heating element. Check to see if the element is grounded or if there are any cracks in the element frame.
Also, use a multimeter to check the thermal fuses and thermostats for continuity.
Is the dryer displaying any error codes?
These are some of the most common symptoms and checks you should address first when diagnosing this issue.
