Samsung dryer model DV422EWHDWR/AA will not start
Brand: Samsung
Model Number: DV422EWHDWR/AA
Main Symptom: Will not start
After hitting Power, Mode light and all 3 lower icon lights (Drying, right arrow, Cooling) lights are on as well as time remaining number and dry level and temp lights are on. After pressing Start, it beeps and starts blinking the Mode light and Drying icon lights. No error codes.
I thought I read that a broken dryer belt might cause this and it should be fairly difficult (resistance, stiff) to turn drum by hand. I vaguely remember it was pretty difficult to turn drum by hand. It now easily moves with little effort.
Does this indicate a broken belt and would cause symptoms above?
Error Code (if any): none
Parts or tests already tried: none
This could be a belt issue, you will need to dis-assemble it to be sure. This could also be a door switch, belt switch or wiring issue.
