Brand: Samsung Model Number: DV45H7000EW/A2 Main Symptom:No HEat What happens & when:
Hello everyone! I have a Samsung DV45H7000EW/A2 dryer and I am having trouble with the thermal fuse on the heater assembly and am not sure what the underlying cause could be. The dryer was working fine for years but quit drying about a month ago and at that time I just replaced the entire heating assembly.
This new assembly worked fine for a couple loads and then quit drying. I found that fuse on both the old assembly and the new one read open when testing resistance.
Both the thermostat and the thermal fuse on the blower assembly read closed, the element shows 12ohms and the thermistor on the blower assembly shows about 12.5k ohms. The blower fan itself seems to spin fine. The dryer sits on an exterior wall and both the flexible exhaust tube and the exterior vent are free and clear.
I’m kinda at a loss for what else I should check. I’m sure there’s something I’m missing but can’t think of it. If anyone else has some ideas on what else to check I would certainly appreciate it. Thanks!
With the heater thermal fuse opening twice, I’d focus less on the controls and more on why the heater housing is getting too hot.
Your readings actually sound pretty normal: ~12 Ω on the heating element is reasonable, and 12.5 kΩ on the thermistor can be normal depending on room temperature.
The first thing I’d check is the heating element for a short to the metal heater housing. Disconnect the element wires and check resistance from each element terminal to the metal housing. You should read OL/no continuity on both. If either terminal shows continuity to the housing, the element can stay partially energized when it shouldn’t and repeatedly blow that thermal fuse.
If that checks good, I’d look closely at airflow. Even though the hose and outside vent are clear, check the entire internal air path—lint filter housing, blower housing, duct from the blower to the heater, and the blower wheel itself. Make sure the blower wheel isn’t cracked or slipping on the motor shaft. A wheel can look like it’s spinning but still not move enough air under load.
One very useful test is to temporarily run the dryer with the exhaust duct disconnected from the wall. If the heater starts cycling normally and the dryer doesn’t excessively overheat, there’s still an airflow restriction somewhere in the house venting.
Also watch the heater while running on Timed Dry/High Heat. It should cycle on and off rather than staying glowing continuously. If it stays energized continuously despite strong airflow, then I’d start looking at a stuck heater relay/control-board problem.
So I’d go in this order: element-to-ground test → internal airflow/blower wheel → run disconnected from house vent → verify the heater actually cycles. Since the same heater-housing fuse failed on two assemblies, something outside the fuse itself is almost certainly causing the overheating.
