Brand: Samsung Chef Collection (4 Door) Model Number: RF34H9960S4/AA Main Symptom: Light wont turn on when bottom left freezer door opens HOWEVER it does turn on when I open the bottom right freezer What happens & when:
Error Code (if any): No Error Code
Hello! Since the light comes on when you open the bottom right freezer door but not the bottom left, that’s actually a helpful clue.
On your Samsung Chef Collection RF34H9960S4/AA, I would start by checking the bottom left door switch or door sensor before replacing any lights or control boards.
The refrigerator may not be recognizing that the left freezer door has opened.
Here’s what I recommend checking
1. Test the left freezer door. Close both lower doors, then open only the bottom left door. Check whether the interior light comes on.
2. Compare it with the right door. Close the left door and open the bottom right door. If the light works normally, we know the lighting system is at least capable of operating.
3. Check the door sensor. Samsung refrigerators commonly use magnetic door sensors rather than traditional push-button switches. Look around the upper edge of the lower freezer compartment for a sensor location, and check for anything loose, damaged, or misaligned.
4. Check the door alignment. Make sure the bottom left door closes evenly and isn’t sitting unusually high or low. A misaligned door or magnet can affect whether the refrigerator recognizes it as open or closed.
One more test worth trying
With both lower doors closed, open the bottom left door and leave it open for about 3 minutes.
If the refrigerator has its door alarm enabled, listen for an alarm. If it never sounds, that would further suggest the left door isn’t being detected, although the alarm alone isn’t a definitive test.
The parts diagram for the RF34H9960S4/AA-01 lists a freezer door reed switch, DA34-00043J, which replaces DA34-00043A. Confirm the full model revision before ordering.
Dey Appliance Parts
If you can access the switch, unplug the refrigerator and disconnect the switch before testing continuity. A typical magnetic reed switch reads near 0 ohms with the magnet next to it and open circuit when the magnet is removed.
iFixit Documents
A quick question
When you open the bottom left freezer door by itself, does the light stay completely off, but immediately come on when you open the bottom right door while leaving the left door open?
That will help narrow down whether we’re dealing with the left door sensor or a separate lighting problem.
Thanks for the info. I’m not able to locate said sensor. In fact, I can’t find any information of the exact location of the sensor on the internet. To answer your last question, the light stays off when the left freezer door is open. In other news, I did the door alarm test. The right door sounds the alarm when opened for a few minutes and the left door does NOT sound the alarm.
