My wife found a royal blue rubber ring, approximately 8-inches in diamter on the bottom of the tub between the heater and below the spray arm. Is this a part of the dishwasher? If yes, where does it go and how would I reattach/reinstall this part?
Hi there,
I have exact same problem. Ring is not broken and assume I overloaded one of the dishwasher racks. If you have figured out where the ring goes I would appreciate any help. Take care
I do not know where it goes as it seems too big.
If you click on the picture pump cover seal (Item 13 in Section 4) a new page will open with info on it.
Problem is it looks smaller (~5.5 inch diameter) using the grid which is 1 inch per square.
