I was linked to this site thru another with part of the answer I was looking for. This one so far is much more help.
The dryer does not heat. The element does not glow either. I checked the continuity of the flame sensor and it is good. Am I to assume then that the heating element is bad? Or could there be another issue?
Found answer in another post. The thermal fuse is bad. i will replace along with the cycling thermostat and see what happens.
