My older Roper dryer wont heat after replacing thermostat, thermal fuse, and the heating element. Runs fine, cleaned lint areas, and will shut off when finished. Any suggestions what to do next?
Replacement parts for EL5030VLO models | AppliancePartsPros.com
Does the timer advance and shut off in both timed dry and auto modes?
If it only advances in timed dry I would check the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=βRedβ]Be careful as 240 volts is lethal !!! [/COLOR]
Have you checked/replaced the hi-limit thermostat and the thermal cut-off (Items 15 and 6 in Section 4)?
