Hello,
I replaced the thermal fuse kit and thermostat because the dryer was working, but not heating. After i replaced the parts, it worked beautifully for about 5 minutes, then it shut off and will not turn back on. I tried replacing them again, but it still will not work. any idea what the problem might be?
Check for any lint clogs. clean & vacuum all ducts & ducts on the dryer.That is probably your issue.
Unless you get plenty of airflow the thermal fuse will not last
Nope, that’s not the problem. I checked it and it still isnt working.
