Rinse Light Continues to Flash
I have already replaced the electronic board and it did not change anything. The flashing on rinse light continues and will not reset by pushing the reset button. The dishwasher will not run, fill with water or anything, just continous rinse light flashing. Does anyone have a solution to the problem? Thanks, Sparkchiller
Check the heating element, inside the lower panel theres a lot of paper work, It will tell you how to reset the control. I think its normal wash-heated dry (repeat 3 times with in 5seconds) all lights flash, let the unit run a cycle and the control will reset
