Replacing the drain pump on a Whirlpool WFW95HEDW0 Duet front load with no access panel in the front
Can you give instructions on how to replace the drain pump on this model which does not have a front access panel.
Brand: Whirlpool
Model Number:WFW95HEDO Duet
Main Symptom: Drain Pump
What happens & when: stops and displays error codes
Error Code (if any):F09 E01
Parts or tests already tried: NO CLOG
Had to piece it together because of the data limits on here, but here’s the relevant parts of the repair section of the service manual for that one.
Front Panel-Drain Pump.pdf (2.1 MB)
Top.pdf (1.0 MB)
Console.pdf (980.9 KB)
