Replacing old Water Level Sensor with new harness and circulation pump on Jenn Air stand alone ice maker
Brand: Jenn Air Stand alone ice maker
Model Number: JIM158XYRS0
Main Symptom: Continuous water filling into the water pan
What happens & when: Only when the unit is turned on
Error Code (if any): None
Referencing this video posted by you fine fellas. Fix Your Kitchenaid Ice Machine’s WATER LEVEL SENSOR in Minutes. That part number has been replaced by W11741505. Looking to understand how this new harness installs given the previous part is discontinued.
For your Jenn-Air ice maker, model JIM158XYRS0, the continuous water filling could certainly be related to the water-level sensor or its wiring.
The important thing to understand is that W11741505 is a replacement harness assembly, so the installation may be different from the older sensor shown in our video.
Before replacing anything, I’d recommend checking whether the water inlet valve is staying energized because the control isn’t detecting the correct water level.
Here’s a quick test:
  1. Turn the ice maker on and let the water pan begin filling.
  2. Once the water reaches its normal level, watch to see whether it continues filling or starts overflowing.
  3. Turn the ice maker off using its control.
  4. If the water stops immediately, that suggests the valve is being electrically commanded open. A water-level sensing problem, wiring issue, or control problem is possible.
  5. If water continues flowing even with the ice maker switched off, suspect a mechanically stuck water inlet valve.
For safety, unplug the ice maker before disconnecting or inspecting any wiring.
Installing W11741505
I confirmed that W11741505 replaces W10485962 / WPW10485962 and is listed as compatible with your JIM158XYRS0. It’s a pump-and-harness kit rather than just the original water-level sensor.
Parts Dr+1
The general replacement process is:
  1. Unplug the ice maker and shut off the water supply.
  2. Remove the ice and drain the water reservoir.
  3. Disconnect the existing pump and water-level sensor connections.
  4. Remove the pump assembly and its mounting hardware.
  5. Install the replacement pump and sensor assembly.
  6. Route the supplied wiring harness along the original wiring path, keeping it clear of moving parts and sharp edges.
  7. Connect the new harness to its matching connections, secure the wiring, and reassemble the reservoir.
  8. Restore water and power, then check whether filling stops at the proper level.
One important detail: I haven’t found a manufacturer installation sheet showing the exact connector-by-connector conversion for W11741505. I wouldn’t recommend cutting wires, splicing connections, or leaving out the new harness without confirming the kit instructions.
There is also a documented case where the replacement kit was installed but the reservoir continued overflowing. The first question raised by the appliance support technician was whether the new harness supplied with the kit had also been installed.
AppliancePartsPros Forum
Could you send me a picture of the new W11741505 kit laid out, showing the pump, harness, and all connectors?
That will help me walk you through which connections are replaced and how the updated harness should be installed on your particular ice maker.
Jeffrey, I really appreciate the quick reply.
It is definitely number 4. The water stops immediately when turned off. Essentially, it fills, overflows for a full 3 minutes. The pump kicks on and water is sent by the recirculating pump up and over the cooling unit. That goes on for about 30 seconds then the drain pump kicks on and empties the water pan. The process starts all over at that point.
I will need to purchase the W11741505. Here is a link with a picture. W11741505 - Whirlpool Ice Maker Pump and Harness | Parts Dr
It appears the new black connectors are for the recirculating pump, the white is for the drain pump, I don’t know what that little white/metal clip is for. I replaced the water sensor in 2024, looks to be a well known issue given they completely changed the design.
Thanks again Jeffrey!
Brad
