Replacing Bosch DW Rinse Dispenser
How do you pull the rinse and soap dispenser out once you have the front door panel open? Do I just pull as hard as I can because it appears stuck.
I can see blue goo clogging the rinse agent area. Is this a unit you can pull clean and put back in or is it buy an entire new part?
