[QUOTE=richappy;17690]For your info. they still sell a bearing kit P# 285203 at about $40, a lot cheaper than $103 plus $25 shipping. However, it is a big job removing and installing the bearings.[/QUOTE]
these are not the right bearings for the maschine he is talking about! I ordered them as well as I have the same machine as him and they arrived today. They are the WRONG ones
Is there anything complicated about the front door bellows and seal and how it attaches to the drum inside?
Nothing complicated. There is a very long wound steel spring that holds it in place. I believe you pull it off first. I don’t remember if the spring is on the drum or door but could guess it is the drum as it would be better suited to hold it.
I hope you are going from an online assembly/disassembly tutorial.
Note, it has been a quite awhile since my project.
cheers
Finally getting back to post the end of the story. I contacted Frigidare parts dep and they said a new drum was ~ $200. When I asked about a warranty they played dumb/didn’t know what I was talking about so I contacted customer service and they said the drum has a 25 year warranty and that the machine was 5 years old. It’s hard to believe that the Frigidare parts department doesn’t know about their own warranty or that a $600 machine would fail (apparently this is standard) after only 5 years (can you say JUNK). Anyway customer service gave me the number to a local distributor and when I contacted them they said it would be about $20 delivery charge. When the new drum came in they never asked for a delivery charge so I got the drum for FREE (yahoo). I put the new drum in without replacing the bearings as they looked and felt solid although I did give them a light greasing. I put everything back together and the washer is working fine. Let’s see how long this drum lasts.
One time saver - Air tools or drill with socket attachment will be very helpful in removing and replacing the numerous bolts holding the drum together.
yes, checking is always good with so many model changes going on. If you type. I just dragged mine into a bearing shop and they gave me the ones to match.
