Fluker
1
Brand: Frigidaire
Model Number:FGHC2342LF3
Main Symptom: Replaced water valve still not making ice
What happens & when: Always
Parts or tests already tried: replaced water valve, checked for frozen lines, performed manual reset
Is there water getting to the icemaker. If not and the lines are clear and the valve having been replaced, this would be a faulty icemaker.
Fluker
3
Water does come into ice maker but at less frequent interval than before. Takes as much as 4 to 5 hours to refill and make a tray of ice.
Check the temperature where the icemaker is. The temp should be between 0 and 10 degrees.
Fluker
5
Temperature on door of freezer reads 0 degrees. Freezer working fine.
This issue sounds like it would be an icemaker issue and the icemaker would need to be replaced.
