Replaced latch dishwasher worked then stopped
We replaced the latch in the dishwasher and it was obviously broken. It worked for two days then stopped working again. The latch looks fine. I ordered a new computer panel and the dishwasher still won’t come on. Any ideas?:confused:
First thing I would check is the power to the unit.
Remove power to the unit and check the wire nuts which attach it to power.
I would re-do them.
Then re-apply power
Check that you have 120 volts at the wire nuts.
Check that the wires up to the door switch and control board are OK.
Next I would check the door switches.
Remove power to the unit, undo one wire at the door switches, then manually activate the switch. It should go from infinite to 0 ohms.
If both are OK then it could be that for some reason they are not being activated when the door is closed.
To confirm this
You could unplug the unit, remove the wires from the switches, short them together and tape them up so they cannot short to anything.
Then restore power and give it a try.
Tape a towel over the tub opening in case it fires up.
If only way to remove power is to flip a breaker you will need 2 people as you do not want it to spray water all over and you will have to kill power quickly.
